'08 SMR450, splitting the cases
djhurayt
I seemed to have developed a weeper oil leak from between the cases. Looks like I need to split the cases. Can somebody give me a brief description of what is involved with splitting the cases on this motor?
With my TE 510 I had what I thought was the same thing. In my case it was the big oil drain plug washer was installed upside down. One side is smooth and the other side is rough. I torqued all the case bolts to specs and was going nuts about it weeping oil on the bottom of the engine. I ordered up new drain plug washers and installed them smooth side up and no more leaking. So check your drain plug washers and make sure the smooth side is contacting the case.
