08 te450 cam tensioner
joshua vieira
My bike has a low rpm rattle which i believe is comming from the timing chain. I notice it more when lugging a gear to high or going very slow. I the valves are with in spec. I pulled the cam chain tensioner and i found it to be at the third click in. Which i believe is suposed to be ok. So then i put back togethor after moving some clamps because 1 was touching an exhaust spring. Took for a ride same noise. Then i removed the tensioner again and advanced the plunger to 5 clicks and the noise seemed to improve alot. So my question is why isnt it pushing out the plunger enough. The tensioner moves freely and the teeth are not worn. The spring seems fibe its not bent or anything.i might advance it 1 more click. Is this a common problem? Is there an aftermarket tensiiner for this. How many clicks tell you that the chain is streched? Thannks for any help youguys can offer
Do a search on a manual cam chain tensioner on here. I can't remember the exact outcome on it. If memory serves me correct, it's the same as a 610. It's probably back 5 years ago or so. Mine is noisy upon start up and after a few seconds it goes away, so I never messed with it. I wanted to, just a little farther down the list.
