08 TXC250 engine swap to 450
ray_ray
Mini-Sponsor
Is it possible to swap an 08 TXC250 engine out for a 08\09 TXC450 \ TC450 engine? I'm thinking I might wanna make a change to a 450 in the future but have limited ways of making this happen on a Husky ...
Why not just put a 310 kit on it? Makes it a whole different bike & offers a good compromise between 250 handling and 450 power.
Swapping to a 450 should be easy enough, but I'm not sure off the top of my head if you'll need to swap airboxes & exhausts......
Yep, I'll probably do the 310 kit down the road also ...I'm thinking long term here and a 450 would be very good for the racing going on here ...
The exhaust might be the biggest issue ... I'm gonna look up the parts number on this item ... air box may not be too big an issue ... The carb might need replacing also ...
I had asked before if a 450 exhaust would fit on a 250 and was told they would not fit. Are you thinking of just replacing the cylinder & head or doing the whole engine? That is pretty major stuff not sure you wouldn't be better off just getting a whole new bike.
Entire engine is what I'd be interested in replacing ... I can not import another bike here so another bike is pretty much out of the question ...
The part numbers on the exhaust are pretty close but the CARB are different sizes between the 2 bikes ...
