08 TXC250 head gasket
ray_ray
Mini-Sponsor
Whats the story on these metal head gaskets? Use once and toss or can these type head gaskets be used 2-3 times?
This is a great story line.. 2 stroke I always went twice unless it was a heat failure or blow up repair.. but the way a 4 stk has to be torn down it wouldn't pay to save the 40-50 bucks and have to tear it down for giggles..lol Just my thoughts.
I know the 2010 TE 250 I had the choice of 3 thickness's
Chow, Carl
Hi Ray I just finished putting the TXC 250 back together andI wondered the same thing and decided to reuse the gasket mainly because it was a steel one and it would have looked no different to a new one if I had bought one same goes for the base gasket.
I found another drama with the engine and that was that the camchain drive sprocket on the crank slipped on and off with fingers and thought that wasnt right, checked manual to confirm and showed hitting it on with a drift. To confirm my suspicion the woodruff ked was fairly worn and I could rock the sprocket back and forth. Imagine what would happen to the valves if it sheered off and lost drive******************************************************************************** still researching it at this stage but cant help to wonder if there are any others out there the same ??
I've never saw a gasket like that before but I'm not big on engine work so they might be common ... They look pretty durable ... I don't see how one could ever blow ...
What about that key? Did you just go to a Hardware store and purchase a new one?
The head gasket is the original and is 3 layers of very thin softish metal coated in some sort of grey coating.
Didnt get a new key in time for ride today so locktighted it and sprocket in only for this ride have to sus out if sprocket is meant to be finger push on fit, I don't think so, but noticed there was less cam timing train noise upon first start up. They are a bit noisy normally but I thought mine was a bit worse before.
