09 TC 450 Carb
CagivaWMX
I started my 450 Sunday morning at home and it was fine. When I got to the track a few hours later and went to ride it....as soon as I turned the gas on it absolutely poured out of the drain hole. I think something is possibly wrong with the little drain screw. I've removed it numerous times and can't find any visible reason this is happening.
The allen screw seems to bottom out and I have about a thread or two left. It won't go in any further...and seems like it should be in far enough to block off the drain.
On the microfische there appears to be no orings or anything that work with this screw. When your guys screws are in all the way and functioning properly do you have any threads visible?
My drain screw has some visible threads if I remember right on the FCR carbs. Did you inspect the float? Sounds like something along that line if it is all of a sudden pumping gas into the carb and out the overflow.. Or is it coming out of the very bottom drain?
Odd.. I wonder if something got chewed up in there so the drain bolt doesnt seal all the way. Did you take the bowl all the way off and look at the drain/bolt/bolt hole closely? If not give it a thorough inside/out inspection
The drain screw is also an overflow, and it's the one fuel "should" start coming out first if the float were to stick. There's a tube on the inside that goes to the top of the float chamber and dumps fuel out that same hose if the level rises to that pooint.
If it were just the screw it should be more of a leak and not, "pouring out" like you say.
check your needle the to p lock cap on top of the slide may have loosened sounds like your nedle maybe stuck. examlpe fine when loaded dropped ou of truck just jarred enough the neddle may hang
