09 TE510 graphics kit and heat protection
ks9mm
Hey Gang,
I am so fast :) that finally last sticker flew off from my 09 TE 510... what's good place to get some graphics to spice things up? I have IMS 3.5 tank and l would like something that fits and stays on :)
another thing is, I am fed up burning my leg, boots, pants on my left leg... any good heat shields that can spare me this aggravation?IMG_0162.JPG IMG_0225.JPG IMG_1372.JPG
I think Hall's had some ventilated tank graphics. I've seen them on a bike in the shop but up close they are marginal looks-wise.
Most decals will not stick after a while on these tanks. I think Motosportz has some heat shield stuff.
Sand is so warrrrrrrrmmm.
You look like a good candidate for a Kush sprocket with that street set up. Ill be waiting to hear answers to your query too, I HATE my 3.0 IMS. Did I mention I HATE it?(I wish I could make hate bigger and bolder)
Uptite in CA has a great heat sheild.
HI Ks9mm, I think image worth 1000 words.
Heat protector is from www.pirieperfprod.com
Very good product , need to check the bolts time to time.
The graphic come from www.moto-stylemx.com (Romania)
It's my personal desing.
I did some modification to make it fit on the Safari tank,
No one do graphic for this tank, It' look smaler with the graphic !
Izn0g00d
The carbon fiber heat shields from Pirie composit products are an excellant way to avoid the burns from the head/mid pipes.The front of the muffler,there are several companies out there making a better guard than the stock one,I chose the one from MotoSportz and have been happy with it along with several of their other products.I also have the IMS tank and had applied decals on the tank that I sourced from a local shop and found that after a few or several months that as with all that are applied to a plastic gas tank,they started to shift or slide on the tanks surface.I'm not sure that this can be avoided because the plastic or whatever the material is that they make the tanks out of has a tendency to gas (as in the gas passes through the tank to the atmosphere) thus making the decal adhesive ineffective.They will bubble,slide,lift,peel and look like crap after a few months.I would say that if you don't mind buying and putting new ones on every few months,to forget about the graphics.
Hi Waserman, the graphic is perforated so the vapor of gas go true, with out wiping out the graphic of the tank. And you need to wear glove to install it. The grease on your hand are not helping keeping the graphic on the tank.
