09 the Lighting Setup
RideLI631
Ok so to those who have pre beemer and ktm bike you know how much the stock headlight setup sucks! I am looking for ideas from people who have solved the problem. Im willing to send out to get rewind of stator if necessary. What headlights have you used and how did they mount up/work? H.I.D. halogen? Did you use the stock housing? or at least the stock fender? Any info much appreciated in advance!
Made a mount off the fork tubes to mount a Rigid led. Have not had it out yet but is night and day compared to stock.
I installed this headlight that only draws 42 watts and it's blinding. They have a programmable dimmer for street use.
HTML:
http://www.bajadesigns.com/ProductDetail?ItemNumber=497001WT
Did this mod on my stator for 90 watt DC output, also called "ground float". Huskys use the exact same K3 stator as KTM. They can do a rewind to get to 130 watts DC.
HTML:
http://www.bajadesigns.com/docs/tech-info/k3-stator-mod.pdf?sfvrsn=4
Also requires this new regulator/rectifier.
HTML:
http://www.bajadesigns.com/ProductDetail?ItemNumber=122004
