09 TXC stator?
not2shabby
Ok, the bike came with a dual sport kit, headlight, tail/brake light turn signals. The battery kept going low after a ride so I replaced it with a new WPS lithium since I think the Yuasa was the original and was about dead. I'm having the same issue with the new battery now. If I ride without the lights on, the battery stays charged, but if I run them it gets low. There's a switch by the headlight to turn the lights on/off. I started the bike and checked the voltage at the terminals and get 13-13.5 at idle and 142-14.5 at 5k rpm, so I'm pretty sure the stator is doing it's job.
I thought the TXC put out enough juice to run lights? Do I need to upgrade the stator or maybe run LED lights? Thanks!
The lights should run off of the stator not the battery. Someone wired it to run off of the battery, but this is a battery killer so they put in the switch. Some more information for you the stator on your 2009 TXC 450 is the same stator that my 2005 TE 450 ran and it had no problem with the lights but they ran off of the stator not the battery.
Ok, thanks! I haven't really looked at how it was wired, just kinda assumed it was running off the stator. I know....nerver assume anything! Guess I'll have to figure out how to wire them to the stator.
Not having much luck finding wiring instructions....should I tap into the DC wire coming out of the stator or an AC wire going into it? I'm guessing the DC since running it off the battery is DC.
