11' TXC 250 Valve Adjust
Yeah in the same boat,mine is te250 2011. Are the shims the same ones that are used in the Hondas.
I think it was .008 exhaust and .006 intake.
Be VERRY careful on the torque on the cam caps.....they are tiny and they will strip right out....I go 42in/lb on the 5mm boths and 55in/lb on the 6mm bolts.
Is it true that if bike is hard to start when hot then the valves should be checked?is this good advice from my mate's.
I think that is a little tight all around.
Does the bike run and start okay?
Keep in mind the left exhaust valve needs to be a little tight to keep the auto-decompressor tang working. Overall I think that is a bit too tight.
I'd check it again when the bike is cold as those measurements seem a little puzzling in as much as they are all consistently .002" too tight.
You don't usually see that. Usually only one or max two valves are out.
