13/14 Red Head impeller fit on 10/11/12?
Cavery
I noticed that the water pump was slightly redesigned for the late model Red Head 250/310's. Even though the housing has changed, they seem to share the same part number for the actual impeller shaft. Because of that, I am assuming that the newer impeller may fit the older Black top x-lite bikes.
Can anyone confirm this before I order the newer impeller?
Cheers.
Shaft may be the same but different housing may mean the size of the impeller has changed??
I would not mix and match as it could affect coolant flow.
