'13 TXC310R valve clearance specs
NCJohnny
Having trouble finding these and can't seem to download manual online. Left side is about 0.18mm, right side is quite a bit tighter. I think I recall 0.15mm being on the tight side and preferable to operate the decompression system, right? How about the intake side? Left side intake is super tight. Only 3 hours on bike. Hot start issues prompting valve clearance check. Dealer replaced (finally) worm drive per Husky tech bulletin. Still not reliable hot starting. Hope this does it. Earthx battery next on my list. Thanks
Finally able to answer my own question for the sake of folks who someday stumble onto this thread looking for the answer: Service manual calls for 0.20 mm clearance for exhaust and 0.15 mm clearance for intake. My intakes are too tight and one exhaust is too tight. The exhaust valve operating the decomp is just about right but I may tighten it up a hair to see what impact that has on hot starting.
NC
Did you have to use a tapered feeler gauge to check the valve clearance?
My opinion and what I did is just removed the starter. It's not ever going to work well. Between the worm drive and the valve clearances etc. your just chasing it around. You'd be better off investing in a rekluse so the bike won't stall. Pull the starter and all the cables running to the starter and save yourself about 4 or 5 lbs of weight!! My bike starts in three kicks cold and on the first or second kick hot and I only wished I had the starter once since I removed it and it probably won't have worked if it was there:banghead: FYI do not remove the battery I thought since the TC250 could run without the battery that this bike should to.....wrong!! I found out the hard way there's a cable running from the battery to the fuel injection system that apparently is necessary for the bike to run!!
Just my 2 cents
Kevin
PS please let me know if you had to use tapered feeler gauges to check the clearances
Huskywood,
When I did mine I didn't use any special types of feeler.
One of my sets is long and thin, so I may have used those.
It's a while ago, but I do recall that it is very fiddly to get the feeler into the slot in the head and then between the cam and bucket.
And for those of us who still like proper old fashioned English measurements, Inlet 6 thou, Exhaust 8 thou
Mike
