1976 WR 360 Transmission Oil Capacity
Take slotted screw out of left side case & fill it with oil or ATF til it drips out. Put screw back in & your done.
No :)
Fill it until it dribbles out of the level hole. This is just below the halfway point. The screw sits just in front of the clutch "bulge".
It is worth fitting a Dowty washer to the M6 screw. No leaks, no shaking loose, and you can keep re-using it.
The manual says 1.6 litres.
If you decide to fill it to the brim, let me know and I'll come round and take pictures of the aftermath :eek:
