1979 Wr390 Rear Wheel
treharne
Hi, I recently acquired a 1979 WR390 in a box, it is missing a few parts for the rear wheel/brake assembly and I am trying to figure out what I need. I am missing the rear axle and it seems that I am missing one or more bushings that support the rear brake shoe carrier and a spacer that goes between the carrier and the swingarm. can someone look at the attached picture and let me know what I might need?
Thanks
You need to figure out if your 79 WR has the 1980 rear brake and swing arm updates. Late or actually around mid 79 production run Husky changed the rear brake peddle, rear brake plate assy, brake stay and hub and swing arm to the what the 1980 WR's use. Can you take a picture of the swing arm, and brake peddle from the brake side or right side and post it? Husky switch to the 1980 WR rear hub starting with frame # MM5594
Marty
Thanks for the replies, My frame number is MM04544, I am not sure where that falls re the updated swingarm. I have looked at the diagrams and the parts manual however I am still unsure of how it all assembles. There is a brass bushing inside the brake housing that is larger than the 15mm axle that is supposed to go through it. is there a second brass bushing that goes inside? as in between the busing pressed into the brake housing and the axle?
Thanks
1st off, it looks like you do have a true WR, once i stood on my head, cause the pic up side down. And after looking at the pics, the swingarm is a WR one, but that's a CR braking plate for sure, so that may need a custom setup.
Anyway looks like your missing Parts #49 (o-ring) & #50 (matching spacer), maybe #40
(inner spacer) too , which can all be a pain to find. Those part can fall out on disassembly
and long storage & get lost, if your not careful.
See this thread , which leads to an even older thread.
http://www.cafehusky.com/threads/wr-wheel-on-cr-80.91324/#post-665736
Luckily WR parts are easier to find then CR ones, if you decide to go the stock route.
If it was me I would make it right and get the 1980 WR/OR rear wheel/hub and the WR/OR rear brake assy and the correct left side wheel spacer and brake rod and bolt it all together. The 80-82 WR, OR, XC and 420AE rear wheels and brake will work. You can sell your CR rear wheel and brake assy.
Marty
Marty, where would one look for a correct wheel and backing plate? Do you guys have a source for parts for these old bikes? I think I have the only one of these around my neck of the woods.
