1983 CR 250 Somme questions
flyingJoan
Ignition advance ? for this motorcycle 10º 0.6 mm looks small advance.Anybody could inform if you have setUp this .My motorcycle have Moto plat 63mm iner rotor
Which oil do you usee for Front Fork SAE 10? im leaving in Spain and is not soo cool.
Thanks in advance if somme body could heelp my
Advance is 20 degrees or 2.55mm BTDC. Original specification for fork oil is 15wt. Good luck with your project and post pictures!
Thanks !!!
In the Technical Data Cr 250 1984 and 1985 the advance is 10º and the rotor is the samme Motoplat ineer rotor 63 mm .
Why this big diference in the advance?
You are correct, it does say 10 degree, but the BTDC measurement is stil 2.55mm. Most people i know use a dial indicator to measure piston location relative to BTDC.
