1999 610 rebuild
Shaggy33
Hi All
I am nearing the end of my rebuild after having engine rebuilt but could do with a little guidance with wiring and carb setting.
I have a couple of silly questions which I foolishly didn't check before dismantling.
One is where a couple of wires go (both have screw ring on end so must be bolted to something). One comes from negative battery wire so that must be earth but have two others (one from HT lead unit at head of frame) and another from the electric box that goes behind battery box (is it a regulator?)
Also I would like to know stock setting for carb main needle as it has 4 positions (marked with notches) but not sure which position it sits in!)
Thank you in advance for any help
