2 Bikes, similar problems:
2013 TXC 310: At the last race we got dirt in the tank (short version – fuel cap popped off). Bike ran for a while but ultimately ran like crap. I assumed I was dealing with a clogged fuel injector. So I tore it apart last night, cleaned the fuel injector with brake cleaner, plugged it into the bike to open the ports and make sure it all get rinsed well, cleaned and rinsed the tank with clean fuel, cleaned the screen filter at the fuel pump and put it back together. I then hit the start button to prime it but did not connect the fuel line to the injector so I could see fuel flow into a clean dish and check for dirt. All looked good, no particles floating in the fuel (I was concerned about the in-line fuel filter). I connected the fuel line to the injector and fired it up. Started immediately but ran just like before…crappy, lean, back firing. I then discovered a fuel leak at the injector…I busted the red o-ring that is between the fuel line connector and the actual injector – held in by 1 Philips head screw. Off to the auto parts store I go…
Question…am I missing a step here of what to clean? I really don’t want to put this thing together only to find I missed a major step.
2011 TXC 250: Bike runs great for about 10 to 15 minutes then it goes into crap mode….nothing above a ¼ throttle…back fires, runs lean.
So…I replaced the temp sensor – nope, not it. I replaced the fuel pump, cleaned the injector, rinsed out the tank, cleaned the filter by back washing it (checked fuel flow and made sure it has no "floaties"…the result? No Bueno. Same stuff.
I am pretty much at the end of my rope…I love the bike, but can’t get it to run.
HELP****************************************! Please J
