Teeszy
I'm in the process of building from the crankshaft up and read gains should be seen from less drag with one less ring on the piston. Also a plus I believe, the TE or forged race piston is lighter. I'm looking at the Wossner kit part number 8866DB and it's on backorder so before I wait weeks for this 2 ring aftermarket race piston I want to get the communities prospective. This bike is not being raced, but being ridden like it if that helps. I am installing a new piece with the sight bubble for seeing where the oil level is since I only have a check screw on my 06 and it's stripped.. I read the only negative is that you have more oil escaping into the combustion chamber so I'm guessing topping off may be necessary. thanks in advance for any thoughts
