So, I have been having trouble starting my Husky basically since I got it. It's an E start only. I put a new plug in it, checked the flywheel weights, cleaned the carb, checked for spark, and checked the valves. While I was pulling the radiators to check the valves there was no coolant in either despite the overflow being full. I filled it with water and tried to start. It was pumping water from the radiator cap, overflow bottle cap, and a head stud while cranking the motor, but wouldn't start. I tightened the head stud and it fired up for a minute or two and died.
The oil is not milky at all. Am I correct in thinking it's the head gasket?
