2000 TE410E brake light
wersmokin
Back in October I had a rear brake issue but it was resolved. I took off the master cylinder for the rear brake. When I put the master cylinder back on I noticed my brake light wasn't working. The wiring is fine and I cannot figure out why it won't work. And yes it's plugged it too. I need help. Is there something that I missed. My rear brake works great. Is it possible there is still air in the line? I am lost on this one. Any advice would be very helpful.
:banghead:
air in the line wouldnt cause the brake light to not work,as long as you put the banjo bolt back in with the wires coming out of it,and plugged everything back in under the seat,it could just be the brake switch,I would try a new one as they go bad all the time
