Me and a friend picked up the bike not too long ago and have been doing a top to bottom tear down of the bike and have found a ton of problems with the wiring harness... The previous owners have been hacking into it and I was wondering if someone could please take pictures of what all their head cluster wiring hooks up to as the clutch safety switch sensor is straight up missing...
We also cannot identify what the red/white wire coming off the key ignition tumbler is.. They crimped a plastic cover over it..
The left hand instrument controls have the two spade connectors exposed and connected to nothing, and the hole in the clutch lever perch has an empty hole where I suspect a depression switch was supposed to go.
We also inspected the main wiring harness for where the neutral gear sensor wire is supposed to plug into, but a single wire connector is completely absent from the main harness and now the neutral sensor has nothing to plug into. The last owners also tore into the neutral safety switch (the three wire dongle near the starter relay) and i would appreciate anyone who could take pictures of it to make sure we repair it properly...
Basically, more or less everything has an issue on the wiring harness and we're trying to fix it...
The bike won't turn over either, but the starter kicks and the cylinder moves up and down. I'll tackle that issue once we get the wiring issue sorted out.
