-Norwegian-
Hello!
I'm having some issues with my '08 Te450 after a complete rebuild/restoration of the bike.
The bike has not been in running condition since 2019 due to an incident where all the splines on the countershaft were completely stripped out by the front sprocket, requiring to split the cases in order to replace the broken countershaft. I began the teardown shortly after this happened, but never got around to getting the engine back together, so I ended up letting an authorised workshop put it back together for me back in november. I have now managed to put the bike mostly back together, however when I tried to start the bike it idled for a couple of seconds before it just stalled and died.
The fuelpump primes as normal when the key is turned or the killswitch is depressed, no strange noises or anything, just normal. The electric start works as it normally would, the bike cranks over and it fires up rather quickly. The bike idles for about 8-10 seconds before it shuts off again. It will then not fire back up until the killswitch or key is switched off and on to make the fuelpump prime again. If one tries to rev the bike during those 10 seconds it just bogs and coughs and does not raise much in rpms.
I have checked all the fuses and they are all ok. I have also checked for worn cables and bad connections, but have been unable to find anything of note.
I'm guessing the issue is fuel pump related, bit I still find it weird that it primes normally when the key is turned?
If anyone has any tips or ideas as to what could cause this issue, I would be very grateful.
Best Regards!
