2009 SMR 510 wont turn over some times
Juvkam78
Almost rady for the first roadtest after installing the Arrow twins and Ecu, have been setting the bike up with iBeat, This have happend a couple of times: the starter kicks in but does not turn the motor, my guess is that it is do too high compression and that the piston is on its way up in the compression stroke the starter is not powerfull enough ? to or three click on the button and it comes to life, alternatly i could just pull the decomp lever, not a big deal but have any of you experienced the same ?
Juvkam
That happens every so often on my 08 TE450. I usually just grab the decomp lever, and then it starts right up.
My '08 has done this once in a while since new. Less often now than when it was new, but it still happens. Rarely, mind you, but it happens. Just pull the decompression lever and let it get past the spot it's at. If it happens a lot, check the battery condition and then look at the auto decompression release. Some people have worn out the decompression release lobe on the cam.
