flyinryanmtb
Hi, I've been lurking for some time and have been able so far to fix all the problems I've had with this bike thanks to you guys, but this one has me stumped.
First off my push start button randomly stopped working (not after washing or anything like that) but the bike would kick start just fine so I figured the relay just went bad or the wires came unsoldered inside the button no big deal. Then today the bike started "burping" or bogging for a split second every couple of minutes so I figured the fuel pump had slipped forward (did the mod of adding extra zipties previously) I also had a similar incident where the low fuel level sensor broke and was grounding out causing a similar bogging but I completely removed that as well as a short in the horn. So anyways after a few of these "burps" the bike started to pop and bog and completely died. As it was dieing I noticed the low fuel light came on which was weird because I had removed the unit. So as I come to a halt in the middle of nowhere I bust out the tools and start troubleshooting. Heres what I checked
Fuses-all good
battery-fully charged
broken wires/rubbing on the frame-nothing
pulled fuel pump etc.- all good
mixed and matched the 3 identical relays on the left side under tank- no change
This is where it gets weird-The speedo is completely dead when I turn the key on, fuel pump does not prime, however when I turn the key off the number 2.1 shows up and the numbers cycle then immediately turn off. Could this be an ECU failure? or do I just have a bad relay? Any help would be much appreciated!
Fuses-all good
. I finally got a new multi-meter and checked the starter relay. I applied 12 volts to it and checked for continuity and had Nothing! I guess this explains why my bike was sputtering for a split second due to the relay failing and "clicking" off then on rapidly. I will post an update as soon as the new one arrives.
