2010 headlight assembly retro fit??
Zestymac
Will a 2010 headlight assembly retro fit to the earlier bikes? I cant tell from the pics if it's rubber strap mounted or not...
And if so, any idea on cost?
Thanks, Rick
I hope someone knows the answer to this... I was thinking the same since its an H4 bulb and much easier to pick up at the auto parts store. Please fit, Please fit...
The lens assembly, minus the shell, looks like it will pop right in to shell of my 08. To bad the lens is still plastic and so a 55/60w bulb probably wouldn't work out.
I recently bought a baja designs lens to reto fit in to my 08 shell. Having some technical difficulties, but I am not planning on giving up on making it work.
Thx Froggie for all your info and pics. :thumbsup:
Froggie...You are da man. :applause: Thanks for the well documented post. I got a price quote of about $110 USD for the headlight/Mask & Brackets. Bottom doesn't look to be an issue; might have to fab something for the top, it looks like it fits into the OEM instrument mount. My 06' is diff...
With that cost I'm looking at other options...
Cheers, Rick
