2010 TE250 Possible oil Pressure light?
aethelred
Is it possible to put an oil pressure warning light or buzzer on this bike? Does the ECU measure the oil pressure?
In the new 250 the cam shafts run directly in the head. This is not a problem if the oil pressure does not drop!!!
I had a Yamaha which droped oil pressure. By the time I noticed the engine/gearbox was wrecked/worn out. I was told I was lucky the Con Rod was still in the engine...
I feel that if I had had a warning very little damage would have been done. These engines rely on high oil pressure. If something like an oil seal fails, be prepared for a big bill and a lot of sulking...
