2013/2014 Husqvarna TE310R Problem
This has been a year + journey, would really appreciate any advice anyone can give.
The bike idles and has throttle up through 20%. After 20%, air-fuel ratio becomes off. Once at 70% throttle into a higher RPM band, it regains air-fuel mixture. Mid-range bogs the bike. Bike runs at idle during cold starts and when up to temperature, so temperature is ruled out of the problem.
ATTEMPTED FIXES:
• new fuel pump
• new battery
• cleaned injector
• replaced spark plug
• replaced throttle position sensor
• checked for air leaks on throttle body
• inspected and replaced relays
• replaced stator
• proper ECU recalibration & placed all sensors into spec
• chased wiring, ensured grounds
• new coolant temp. sensor
Thank you in advance for your help!
