Lazylaser
Here is an interesting issue.
I went to set my idle knob to the factory setting and work from there since I didn't like how the bike was idling and popping when rolling at low speed.
Using the manual I made sure that the bike was warmed up, then with the knob pushed in I spun the knob counterclockwise (left) until it stopped. Interestingly enough it only went four "clicks" before not being able to turn it anymore. (approx. 3/4 of a full turn)
I thought this was interesting since the manual call for the knob to spin 34 clicks to be normal idle setting. So, I adjusted out to 34 clicks and the bike wouldn't even start. I went between dead stop zero to 8 clicks clockwise and the bike seems run the same. ( I returned the knob to 4 after tinkering) which is where it runs and where the previous owner had it set.
I have the Leo Vince tune put on by zipty racing, no cat, FMF and (I did just find the ORANGE AIR FLUTE in place, although the previous owner told me it had been removed.)
I'm assuming I'm lean given the popping, high idle (by ear) and non-ability to adjust the idle knob. So Given my symptoms, It seems like I'm getting too much air probably between the adjustment knob and the head. Maybe that boot that holds the FI is torn, or something like that.
Anyone run into this before?
