Anybody got some info on the map switch for the  husky 2013 TE310
Little bit of info on my bike.
Has had the CO2 sensor removed and the "power up plug installed" actually have not spotted the power up plug myself but the previous owner said he had the "race mods" done to it. Airbox,filter, pipe etc etc
As it is as the moment for me it goes very well, and VERY responsive,,, possibly a little too much ie: on a hill on choppy tracks it will lift and carry on with a small amount of throttle. (yes i will look into sprocket ratios also)
SO..... Looked at adding the "MAP" switch/ connector. This will (apparently) alter /retard the ignition a little and make for smoother power application to the rear wheel…
At the moment with the bike running my speedo cluster does not show any map modes ie race map I or race map II…
So I presume it defaults to uncorked full on mode.
race map 1
(speed lcd lights all the display options during starting of the bike so it does have the modes available)
flashed all for 2 seconds or so
Now the problem…Found the map connector at the front of the bike under the front head light assembly along with all the other connectors.
Measures 5 volts DC across the two terminal when running
(wire colours on the connector blue and white/black(trace)
From what I read on the husky forums the switch needed is one of two types
A: momentary type. Press for 3-4 seconds while bike is running will change MAP mode.
B: Two way toggle that applies a short circuit to the connector wires before the bike is started.
Also read that the coolant needs to be at 40C or higher for the race mode to be able to changed??? Allowing the bike to be fully warmed up I suppose??
I have tried shorting the two wires (admittedly when the bike was still cold, may need to try when it`s fully warmed up
A: Tried the short circuit 3-5 seconds when the bike was running…nothing, no map modes on speedo shown
B: Tried the short circuit before the bike was running…nothing, no map modes on speedo shown
So any info would be a great help…
Cheers…
race map 1
Cheers…
