2013 TE 511 clutch issues
FarNorCalStix
I recently bought a 2013 TE 511. I've noticed it has a little bit of clutch drag. Enough clutch drag that if its running it doesn't want to go into neutral.
The clutch lever adjuster is screwed all the way in and I have tried using a shim to get full travel out of the master cylinder.
The fluid looked like mud. I completely flushed the hydraulic system using DOT 5.1 fluid as listed on the master cylinder cover. I used a plastic syringe forcing all the fluid from the bleeder on the slave cylinder upwards towards the master cylinder and then bled the clutch the traditional way to ensure there was no air in the line.
The previous owner made a comment about buying cheap brake and clutch levers. I also installed a new clutch lever that is a motion pro direct fit lever.
Im at a loss at what to do at this point. I did read about the clutch pack shim but cannot locate one. I have been searching for a clutch kit. I Found a couple of friction discs in Europe. Is there a clutch kit made by an aftermarket company that is compatible that is readily available? I dont seem to have any luck using the shop by make and model options through any of the many websites I have searched.
Any help would be greatly appreciated.
The OEM part number is 7722570 and is compatible with;
CLUTCH (TE 449-511 ) (2014 )
CLUTCH (TE 449-511 ) (2013 )
CLUTCH (TC 449 ) (2013 )
CLUTCH (TXC 511 ) (2013 )
CLUTCH (SMR 449-511 ) (2011 )
CLUTCH (TXC 449-511 ) (2011 )
CLUTCH (TE 449-511 ) (2011 )
CLUTCH (TC 449 ) (2011 )
CLUTCH (TC 449 ) (2012 )
CLUTCH (TE 449-511 ) (2012 )
CLUTCH (SMR 511 ) (2012 )
CLUTCH (TXC 449-511 ) (2012 )
This might widen your search.
@Ghostman has one for you (in europe); https://ecbike.pt/en/husqvarna-red/1789-clutch-pack-449-511-7722570.html
I couldn't find anything so I bought the one in your link from ghostman. Cost me almost $450. I really love this bike. I just wish all the parts were still manufactured by either BMW/Husqvarna or a better supplier of all parts aftermarket. I knew parts were going to be a little bit difficult to source but I didn't expect them to be this hard to find or this expensive. Like I mentioned this machine is super fun but I might see a new husky or ktm in my future.
