Here is the story: 2014 TE310R with a bit over 2000 miles. Had a radiator hose (the one going into the waterpump) spring a leak out on the trail. By the time I noticed, I ended up dumping 24oz of creek water into the radiator. Fixed the hose, straightened my radiators and bolted it all up and filled with Engine Ice.
Couple of rides later, countershaft seal was leaking oil, and eventually started billowing white smoke. Nothing out of the exhaust, just from the seal. Had to add distilled water to the radiators, figured it might have been that I didn't properly burp the coolant system from when I tore it down.
Replaced the seal, ran it around the block and didn't see any smoke. Good to go! Wrong. Less smoke, but still blowing past the seal.
Now, here I am wondering if I just do a headgasket or while I have the engine out of the bike, should I do the piston / rings as well?
The problem with doing a piston on this bike is that I am having a hard time finding piston kits for them - plenty available for the older versions.
https://www.procircuit.com/high-compression-piston-txc-te-310-13.html
This is the only piston kit that I have been able to find.
Any advice would be welcome. Thank you!
