310R Riding w\o Battery.
NYCMX
Ok so since my electric start dosn't work anyway I decided to ride it without the useless battery. It seems to kickstart and run fine. Think I'll have any problems?? 2013 TE310R.2014 016.jpg
Ok so since my electric start dosn't work anyway I decided to ride it without the useless battery. It seems to kickstart and run fine. Think I'll have any problems?? 2013 TE310R.View attachment 55032
If you like kick starting the bike there is no issues - personally I would sort out that electric leg they can work nicely?
According to the book, it's not recommended to run without the battery
It will run, and the capacitor will store enough charge to start the bike, but the alternator will be charging too much and will probably end up burning out the control circuitry.
Mike
Thinking further on this . . . .
The output from the regulator will probably be fairly spiky, not nice smooth DC. It will need the battery to help smooth out the voltage.
The last thing your FI controller needs is spiky voltage.
Coupled with this, the regulator will probably kick out it's highest voltage, as it won't see the battery voltage and assume that the battery is flat.
So you get a high voltage AND spikes. Not good for any electronic circuitry.
My advice: don't do it
Mike
