cOrPsE
Sorry for so many threads about my bike but it has been sitting for god knows how long. So far ive replaced the air filter, cleaned the gas tank, bled the brakes, cleaned/unseized carb etc etc. So today was startup day and when i was draining the old oil sadly i saw coolant coming out with the oil. Even worse, the coolant has like fuckin crystallized and little white chunks all on the inside. So i got most of it out by putting oil in and draining it couple times. Anyway as a quick test i put water in the radiator, and it came out of the drain plug so something is obviously wrong. I got an RM80 back in day that had coolant in the oil and all that was wrong was an arm that moves the water pump was detached. Attached it, bike ran mint. Anyway, although this bike sat along time i dont think this guy barely even road it. The frame, swing arm etc etc have no scratches, no rust anyway really, and there is no leaks that lead to the exterior of the motor. Motor is so clean you can eat off it (exterior wise). So is it possible the headgasket is no good or maybe the water pump is seized or something? Basically just looking for some insight before i dig in.
