430 auto
Whats a late model 430 auto worth? ratty looking but good mechanicals...
I was quoted to buy a motor that was running but unknown trans condition from a wrecker over $2k so its what you'd be prepaired to pay remebering that they soak up money as fast as a boat because free wheel cluctes start at $1k for a set, the trans oil must be replaced after every ride (1ltr at $19ltr & usually bought by the 20ltr drum from melb) as well as all the other little primary clutch niggles (clutch drum,shoes,springs, starting pawls & springs) that will arise, but in saying that they are very addictive hence I have 3 (2 old & 1 Nauto). If you do buy 1 make sure before you ride it that the carby inlet rubber has not perished with cracks which causes it to run lean & seize & it has clean trans oil in it.
Apart from that have fun,
Speedy
thanks for that, mechanicals on autos r always the main issue eh. $.1.5k max i wll offer
