45 tooth sprocket
richard kersten
I run mostly fire roads with some decent hill climbs , was wondering if the stock chain will work with a 45 tooth rear sprocket, don't wanna go higher than that cause I have to use some highways to connect the trails... Thanks
No. The stock chain was really short to begin with. Consider a 47-48 tooth and look at gearing commander for the speeds you plan on running. I had a 45 for awhile as I too thought I'd need it for 55 mph roads. In reality I haul the bike, and if I am on the road it is a 45 mph road. I got a 50 and another new chain. Works great all around and even on the 45 mph roads. A mile or two above that is doable, just not sustained. Less slipping the clutch on those hills as well.
Alot of clutch slipping with the stalk
