450SM to 510SM conversion
jyrider
Does anybody (Especially George E) know what parts are required to convert a '08 or newer SM450 to a a SM510? Is it just a piston/rod swap or is it a whole top end and ecu change. I should say I'm just talking about the engine.
Seeing as I just pretty much did that; crank and rod, cylinder and mounting studs, cam chain & balancer. Not an affordable option if you already have a functional engine. If you blew up the 450, and had to rebuild it, then it's just bit more costly.
