610/630 side panels - interchange?
Taranis
Does anyone know if the side panels from a TE630 will directly fit a TE610? I'm talking about the ones on the back that go over the silencers. I'm thinking of mounting a tool tube on the right side of my 610 where the 630 carries its superfluous silencer, and thought the 630's plastic might be the answer to packaging it cleanly.
I'm thinking...no. The subframe is different as well. If I had a parts catalog for the 610 I could verify that. Part #'s for the 630:
RH - 8000 H1883 or 8000 H2189
LH - 8000 H1884 or 8000 H2188
Probably one or the other has the large '630' on it. I would assume the lower digit number would be the plain white one. There's also a 3rd version they call 'Rossi', whatever that means. I think that one is red and black for the SM.
No traction on the ADV thread, eh?
BTW, the second silencer isn't superflous, it's active. Mine have been converted to full flow-thru's with 2" SS perf pipe. Dropped about 8lbs and really opened them up.
Different part numbers, different colors.
Perhaps they fit the same way though, they look similar.
You're welcome to take a look at my 630, I'm in north OC, Placentia.
