610 Cam Chain Replacement tools 2006. Puller Mainly
chamber66
I looking at changing the cam chain on my 2006 610
Can so.eone tell me what tools/parts are needed
I have found this on the web
800058541 --> Husky Cam Chain $95.95
38010019 --> Motion Pro Flywheel Puller (labeled YFM, 35mm X 1.5mm) R.H.$38.99 unless ya want the one from husky which is around $100
800063644 --> Waterpump Gasket$4.99
161503601 --> Valve cover Gasket x2 $2.99
bt I have also found the the puller is
28 x1.5 male rh
can someone confirm the size please. And anything else im likely to need?
TIA
Also found this so really confused now
You should also replace the water pump shaft seal and the cam bearings. The cam bearings are a standard size c3 explorer skf bearings.
While you're in there, check your rocker bearings and bushings.
I made a puller and I have a crank sitting in the workshop, I'll go measure it.
Yesbi intend to do all that
Justbi can't find a definitive answer as to what size pullerbi need.
P.s huge fan f sky a d fag bearings
Flywheel thread is m35x1.5mm.
The motion pro tool you linked is the correct one.
Last question
"The cam bearings are a standard size c3 explorer skf bearings."
What are the dimensions of the cam bearings.
Im in the uk st the moment and my bike is in france so want to get everything ready for me to do the work over the Xmas period
Last question
And im guessing I need 2?
