huskyte610e
Questions regarding the Hydraulic Clutch Kit.
1. Can someone please advise on how to 'Adjust' the clutch with this kit?
I initially installed the kit bare, but the bike just wouldn't move with the bike in gear, and the clutch lever pulled.
So i installed some washers, between the brass bush and the bracket (about 6mm).
This made a fair bit of difference, but now the bike is 'hard' to push.
I'm cautious abut installing more, as there appears to be a fair bit of load on the clutch arm as it is with the kit installed?
2. What is the purpose of the Red adjuster at the clutch lever? Obviously, this is an adjustment, but is if affecting the stroke, or just the lever position?
3. How much 'pull' is there meant to be on the clutch actuator. It appears that the maximum i am getting is about 8mm. Is this correct, or does the system need bleeding etc?
4. The cluch lever appears hard to pull. i.e: about the same as the barnett cable i removed. Does this sound right, as i was expecting it to be almost nothing?
Thanks in advance
Thanks in advance
