610 oil pressure/flow to head
Bahr
I decided to check my oil pressure after rebuilding the head and although using the starter, eventually oil started to dribble out of the fitting (not exactly rapid); when I hook up a gauge and start it, I don't get movement on the dial. Are you supposed to get oil pressure at idle (I'm not revving it up until I know it's oiling correctly)?PXL_20260314_030835629.jpg
If the fitting was leaking then I would think there should be some sort of pressure reading on your 15lb gauge. I'm not familiar with 610 anatomy so I'm afraid I can't be much help beyond my 2 bit comment. Did you bleed the air from the line the gauge is connected too? An air pocket will not compress and provide a reading the same as oil will.
The fitting was not leaking, but it's a pass through fitting that I made that allows oil to go on its normal journey to the head, it's just a tee.
I did not bleed the air; air pressure should register on the gauge the same as oil?
I mean do these bikes even have residual oil pressure at idle, or is it basically just trickling through the engine? There's no pressurised rod oiling I guess.
So I pulled my oil pump apart, checked clearances and then decided it was all ok so put it back together and just sent it with some revs and I got 2.5psi on the gauge with moderate revs. So it does generate some pressure, just not very much.
It's been a while since the last time I disassebled that oil pump, I think more than 10 years.
As far as I rememeber, you need to be careful with the alignment of the components since the two radial holes of the pump body, P/N 8000 73518, need to be aligned with the two radial holes of its seat in the right cranckase cover, or the pump will push air only:
Yes correct, but the pin locating into the case prevents it going on the wrong way.
I find it easiest to install with the pump shaft already in, then I use some knipex flat jaw pliers to rotate the housing and pump shaft until it presses down completely flush with the housing before I put the print, gasket and cover on.
