610 TE---450 TE Radiator guards.
Blazes
I have a set of radiator guards--home made for my 07 TE450. Just looking at them they look as if they will fit on my 09 TE 610. Just did some rough measurement and they seem to be a match. Are they the same ? Can anyone give me some info please--Before i go to all the work of stripping my 610--Thank's
No, they are not the same. The mount points do match up however be sure to look at the radiator overflow tank. The way it sneaks out in front of the right radiator may be conflicting. As well I'm led to believe the upper frame bosses may be different as well, 12mm boss rather than a flat clip style. You may, depending on the style of guard, be able to modify to fit...... YMMV
I've been working a with Mohard Racing to try and get guards that work for us. Most likely a little ways out.......... call them and encourage that they get done :smirk:
Thank's for the input--looks like i will just have to strip and see if they are going to work. Nothing is as easy as it seems.
