630 Noise at Startup
Rob578
Picked up a new 630 on Wed. and between rainstorms I've managed to put 35 miles on it. One thing I've noticed is that the engine is extremely noisy for about 30 seconds then it abruptly stops. Doesn't sound anything like a lack of oil pressure, valve noise or anything else I would expect to hear from a cold engine. Any ideas?
30 seconds is a long time for the decomp noise, should quit in just a second or two. Use the cold-start lever - the one that looks like what everybody else uses for a hot-start. :thumbsup: Took me a month to figure that one out.
Should fix itself with some break-in miles.
Power-up, and set hot idle for about 1700-1750, will cold start easier.
Where is the auto-decomp on a 630? Can't find anything about it in the shop manual...
Not saying it's not there, it just isn't on the cam gears.
That's exactly what it sounds like, didn't know it had one.
I gotta lot to learn about 4T's
It's on one of the exhaust cams on my KTM, but I didn't think to look for it when I had the 630 cover off. Just assumed it had one.
Ah I guess it's the little flappy lobe thing to the right of the right exhaust cam lobe.... Not that I think about it, I remember seeing that when I did my valves.
Rob,i had the same problem with my 630 ,it appeared after 300 miles.My dealer is new to Huskys and wanted to keep the bike until they were sure of the cause.They fitted a new auto-decomp and now as CJ says its noisy for a few seconds but a quick rev and its fine. The 630 unit is quite a noisy one anyway but gets better once run in and the valve check is completed
