jaxpc
Is there a specific torque setting on the 8 clutch backing plate adjusting
bolts? if not, should the 8 nuts be even with the level of the backing plate
before you bend up the lock plate corners, or below the level of the backing
plate? Would it be ok to trim the length of the 8 backing plate screws so they
would not hit the clutch cover when the clutch is fully engaged?
