73/74 vs 76 forks
auto
Just put new fork seals in a set of 76 straight legs forks.Just took notice that they do not use a top out spring.They use a fiber washer instead.Also there are no rebound holes at the top of the damping rod.Anyone out there know how the rebound is controlled?Is the fiber washer for rebound or top out.Do they perform better than the earlier forks.I put 200cc of 15wt oil in them,it feels light when you pump the front end up and down.
Those forks always need the top out washer replaced, as they get old the oil just blows by. The damper rods are tapered and there are no holes used with this design.
