75 CR360 Bing Jetting
dkwkid
I rebuilt the Bing carb on the 360. The manual called for a 3.18 needle jet but the Bing Agency had a 3.17 so I went with it. He sold me the "fat" needle which goes in from the bottom of the slide. With a 195 main it is too rich. I dropped to a 185 and it is still to rich on the main. I don't want to run it down too lean. Is anyone running a bing on a cr360? What jetting are you using?
I not sure which one the "Fat Needle" is or you location so I really can't answer your questions without askings lot's of questions, so my best advice is get the Bing Manual from them, study it well and it will answer all your questions, it did for me. Best $11 you can spend! My 75 250CR still wears her Bing Vergaser!
I know the theory- I just need the actual size of the brass you are running. Unlike a Mikuni there is no number on the needle. Low and mid run good, i just don't like to step it down too many sizes from what is published. It says 195 stock and a 185 is still too rich plus I have to order jets-none are local here in Los angeles.
