75 WR 250 No spark
T Klingerman
Hi new to the board, don't know if this belongs here, but been riding bike 2-3 times a week and tonight it started hard , did 1 lap and it felt sluggish. I could tell it was going to die , thought maybe out of gas, nope, maybe a fouled plug, nope. checked for spark , nothing. Maybe a Pro can give me what to check and in what order. The bike normally performs flawlessly. I tell people it doesn't even know it's got my 220lbs on it slowing it down! Thanks for any and all advice. Tracy.
If it has the points ignition I believe the 76 WRs had the place to check is the points and the inside of the flywheel for corrosion on the magnets. If that doesn't help check the output of the coil.
It may seem a really dumb question, but did you try a new plug ??
If that does not work, get the multimeter out and check the earth between the motor and frame, and the earth points for the motoplat (if it has one). It may be possible that the motor mounts have come slightly loose stopping the earth.
Otherwise go with what Jimspac said above.
