77 250WR Clutch Problem
ken_hale
Guys,
I disassembled the clutch to figure out a problem with it not disengaging. The steels and bands (clutch pack) was like "glued" together, so no separation when clutch lever applied. The parts still look like new, are within 26mm thickness wear, and properly adjusted. I reassembled it dry and clutch disengages… I used 1.6L Castrol 30 wt oil in the crankcase. Could this be the problem and do you recommend a different lubricant?
Thx
Very common for plates to stick together, when the bike sits for a length of time.
Sometimes in only a few weeks. They usually free themselves after the motor is in gear.
I use Bel-Ray 80wt gear lube (pours like 30wt oil).
I don't think you have anything to worry about, just ride it often.
