78 cr390 fork seals
dirty mike
Hi I'm new to this site. Just picked up a 78 cr390 in a basket. Trying to get it into at least a roller. I need some fork seals, I remember back in the day we used honda seals. Does anybody have these part numbers.
Also do the front forks have a seal or rubber washer that connects the fork slider to the damper rod, I don't see a seal in the parts fiche.
thanks
You may have a problem getting them from a Honda dealer as the last I heard there is very limited support for parts for 10 yr and older models. You can take one of your removed seals to a bearing supplier and get a quality seal for less money than an OEM dealer
I've found them on Ebay. Search "Honda CL77 fork seals" currently 24 listings.
