81-83 430 wrist pin bearing info needed
motomwo
I am looking for a replacement piston wrist pin needle bearing for the 81-83 430WR/XC/CR motor and was wondering what bearing part number and manufacture others on here are using in place of the oem bearing # 161183801. Thank you for the help.
Marty
Not long ago I wanted a Wossner piston kit for a similar big bore husky. Searched everywhere in the US, all out of stock for the size I needed. Contacted Andy at HVA-factory. He not only had the wossner piston kit but I think he even had an original Mahle. Not only that, he had wrist pin needle bearings as well. I did not specifically ask what brand it was, he just asked if I wanted the bearing also and I got it to. From the UK to central USA, the package was on my porch within a week. He is a sponsor on here, and has a link back on the forum home page under the sponsor section.
Thanks for the referral. Good to hear when we do things right!
Yes, plenty of small end bearings in stock for all the primary kick bikes...
Andy.
Andy.
Hi Andy, What is the width of the 430 wrist pin bearing you sell and the brand/manufacturer and part number?
Marty
The replacement from husky has been a little shorter than the origional for quite a long time perhaps 15 years or more. I don't remember what I did last time re used one or used the slightly shorter one all came with husky part numbers well the shorter ones came through the proper channels. I have seen yamaha on the side of a rod, if you work the search hard enough someone else actually stated what years and models fit. One would expect the pin in the piston to be the same. I doubt walking into a yamaha shop to cross reference a bearing is as friendly expierence as 30 years ago. Not sure if my commen is of any help.
Fran
Widest readily available 18mm IDX22mm OD pin bearing I know of would be 1990-2007 Kawasaki KX250,23.8mm long,Wiseco B1022 or Kawasaki OEM 13033-1010.250-390cc with narrow 23mm small end use Wiseco B1003,which is 18X22X22. 490 Maico and 490 Yamaha is larger at 23mm OD,Wiseco B1014.
Hi Dave, Thank you for the helpful info! I will start looking for the KX250 wrist pin bearing. I am currently using the Wiseco B1022 which is 23.6mm wide. :thumbsup:
Marty
