81-83 Rear Wheels
racer726
Will a 1983 Husqvarna 250 rear wheel fit on a 1982 Husqvarna 250? I believe that they used different backing plates, but I'm not sure if the brake shoes are the same. Axles the same?
I've got a 1981 hub on it right now and want to change to the newer non conical hub. Looks stronger to me and I've got a new set of spokes sitting here for a 1982 model.
I can switch wheels, the whole wheel with no problem. The cr backing plate is different I kind of think the shoes are narrower but you still can use the wheel so long as it isn't worn too much in the drum area. I wouldn't be too optomistic about lacing the rim from the conical hub to the non conical hub. It might work out but the angles of the holes might be different. Cr excluded 84-85 or so the shoe contact area got thinner and more of a stepped fit between the hub and backing plate. There are some backing plates so one can use up to 1988 wheels on what you have.
fran
I have a spare for my auto, as we often have to run on trials tyres at the rear on military or forestry ground and you can't find 17" trials tyres. The spare is a two sided from an unknown donor not conical and its a straight swap over
In 81 the 430 got the new flanged hub, but some "smaller" models still got the older conical. So he could have an 81 conical hub. In 82 all got the new hub.
