'81 FRONT WHEEL
speedcowboy
I HAVE A PROBLEM WITH THE SPACER NR 46 IN THE PICTURE! MY FRONT WHEEL DIDN'T HAVE A SPACER IN IT AND IF I INSTALL THE SPACER THE BEARING LOOKS OUT OF THE HUB. SO WHAT DO I DO WRONG?
Besides having the cap lock key stuck I am not sure if you did anything wrong. If you have a speedometer or odometer drive the spacers in that area aren't the same. Just from memory. You definately need the spacer with the sponge thing around it between the bearings. What do you mean looks out?
